Register HVPcontrol
Register HVPcontrol registers the HVP ActiveX control for HyperView Player.
Note: You must run Register HVPcontrol as an administrator.
                Start Register HVPcontrol in Windows.
- Click Start > Altair 2023 > Tools.
 - Right-click on Register HVPControl 2023 and select Run as administrator.
A message is displayed stating that the registration was successful. -
                Manually switch to a previous or newer version of HVP ActiveX control.
                        Using your file browser, locate HVPControl.dll,
                            which is usually found at C:\Program
                                Files\Altair\<version>\hwdesktop\hw\bin\win64.
                        Windows has a program called regsvr32 that is used to register controls. The HVP control is a 32-bit library so you would use the same regsvr32 program to register on a win64 machine.
                        Go to Start > Run and enter regsvr32 followed by the
                            path and name of the control you want to register.
                        Place the path in quotations. For example, to register the HVPControl.dll enter:
regsvr32 "C:\Program Files\Altair\<version>\hwdesktop\hw\bin\win64\HVPControl.dll"
                        Click OK.
 - Click OK.
                        To view a list of options for the regsvr32 program enter only
                                regsvr32 in the run box and click
                                    OK.
                        A list of options is displayed.
