Friction Block
| Parameter Name | Dimension |
| Mu_Static | Specifies the static friction coefficient
                                         in the
                                            connector.
 This is a mandatory parameter and it must be specified. Recommended Value: 0.5  |
| Mu_Dynamic | Specifies the dynamic friction coefficient
                                         in the connector.
 This is a mandatory parameter and it must be specified. Recommended Value: 0.3  |
| Analysis_Modes | Specifies the analysis modes for which the frictional effect
                                    is on. The choices are the strings:
 This is an optional parameter that defaults to
                                             Recommended Value:
| Effect | Specifies the types of friction models to support. Available
                                    options are:
| Transition_Velocity | The absolute velocity at which the friction transitions from
                                    dynamic friction to static friction. TRANSITION_VELOCITY
                                        > 0.This is a mandatory parameter and it must be specified. Recommended Value: 0.1 mm/second.  |
| Bristle_Stiffness |
                                     Specifies the bristle stiffness in the LuGre model. Usually represented as .
 This is a mandatory parameter and it must be specified. Recommended Value: 100.0/mm.  |
| Bristle_Damping | Defines the damping coefficient for the pre-displacement (or
                                    stiction) regime. Its main role is to damp out bristle
                                    vibrations in the pre-displacement regime. Usually represented
                                    as
 This is a mandatory parameter and it must be specified. Recommended Value: 0.316 second/mm.  |
| Slip_Damping |
                                     Specifies the coefficient for the viscous damping force that occurs when relative sliding actually begins. Usually represented as .
 This is a mandatory parameter and it must be specified. Recommended Value: 0.0004 second/mm.  |
| Torque_From_Preload | Specifies the preload friction torque in the Spherical
                                            Connectors.
 This is a mandatory parameter and it must be specified. Recommended Value: Not available.  |
| Ball_Radius | Specifies the radius of the spherical
                                            connector.
| Parameter Name | Type | Dimension |
| Mu_Static | real | No-Units |
| Mu_Dynamic | real | No-Units |
| Analysis_Modes | real | - |
| Effect | real | - |
| Transition_Velocity | real | [L][T-1] |
| Bristle_Stiffness | real | [L-1] |
| Bristle_Damping | real | [T][L-1] |
| Slip_Damping | real | [T][L-1] |
| Torque_From_Preload | real | [F][L] |
| Ball_Radius | real | [L] |
[LUGRE_FRICTION]
MU_STATIC           = 0.0
MU_DYNAMIC          = 0.0
ANALYSIS_MODES      = 'STATICS_AND_DYNAMICS'
EFFECT              = 'SLIDING'
USE_FORCE           = 'YES'
TRANSITION_VELOCITY = 0.1000
BRISTLE_STIFFNESS   = 0.0100
BRISTLE_DAMPING     = 0.31625
SLIP_DAMPING        = 0.0008
TORQUE_FROM_PRELOAD = 526.882
BALL_RADIUS         = 10.0
