The bodies connected by the bushing are flexible and may deflect under the load being
        transmitted. This phenomenon is modeled with the Mount Stiffness feature. Mount stiffness
        models the structural stiffness of the bodies, thus mounting the bushing as a linear spring
        and damper in series with the bushing in each direction.
        Modeling Mount Stiffness
            The mount or structure surrounding a bushing deflects under the force transmitted by
                the bushing. The local stiffness models this deflection. If the I-Body and J-Body
                connected by the bushing are modeled as rigid-bodies, then you must estimate
                structural deflection separately and add that value to the bushing-rubber
                deflection. Mount stiffness is NOT required if the two bodies are modeled as
                flexible bodies.
            To include local structural stiffness in the bushing model, you enter the combined
                local stiffness of the I-Body and J-Body, and then set the local stiffness flag to
                active.
            When one or both bodies is flexible, you specify that the mount stiffness is
                conditionally active only when the I-Body and J-Body are both rigid.
            Let:
                    - be the bushing deformation in the kth direction.
                    - be the net local structural deflection in the kth direction.
                    - be the local structural deflection of the I-body in the kth
                        direction.
                    - be the local structural deflection of the J-body in the kth
                        direction.
be the local structural stiffness in the kth direction.
                    - be the local structural stiffness of the I-Body in the kth
                        direction.
                    - be the local structural stiffness of the J-Body in the kth
                        direction.
                    - be the local structural damping in the kth direction.
                    - be the local structural damping I-Body in the kth direction.
                    - be the local structural damping of the J-Body in the kth
                        direction.
                    - be the bushing force in the kth direction.
            Then the net structural deflection for the kth direction is:
            Since the I-body structural stiffness, the J-body structural stiffness and the
                bushing act in series, the forces in kth direction in the bushing, the
                I-body and J-body are all equal.
            Therefore:
            Through similar logic, one can conclude:
            The structure and the bushing act in series. Therefore they must generate the same
                force:
            The above equation is integrated to yield
                , where the structural deformation
                is known and accounted for.
