Generic Bushing Model
The following describes a generic representation of a bushing model.
Let:
  • t be the independent variable time
  • p be a set of model coefficients or parameters used in the bushing definition
  • x(t) be a set of internal states used in the bushing model
  • u(t) be a set of known inputs provided to the bushing
  • y(t) be the forces generated by the bushing (the outputs)
Then the general form of the equations representing a bushing is:(1)
F(˙x,x,u,p,t)=0y(t)G(x,u,p,t)=0F(˙x,x,u,p,t)=0y(t)G(x,u,p,t)=0
The functions F(…) and G(…) depend on the bushing model that is used. The above equations can be combined into one single expression having the form:(2)
H(˙x,x,u,p,y,t)=0H(˙x,x,u,p,y,t)=0
