Create and Edit Parameters
In the LS-DYNA, OptiStruct, and Radioss user profiles, certain entities can be defined with parameters in the Entity Editor.
Create and Assign a New Parameter
Edit a Parameter
                Right-click on a parameter assignment field, or click
, then select Edit
                        Parameter from the context menu.
             - In the Edit Parameter dialog, modify the parameter's data.
 - When you are finished making changes, click Close.
