Tracked Vehicle Modeling
In this tutorial, you will learn how to use MotionView to build a tracked vehicle and simulate a track vehicle on a soft soil road passing over a few obstacles.
Before you begin, copy the file(s) used in this tutorial to your
                    working directory.
        Model Overview
- Open a new MotionView session.
                From the File menu, click on Extension
                        Manager and load the Vehicle Tools
                    extension.
Figure 1. - Open the Track_Start.mdl model file.
                Review the model.
- The model is in the mm, Kg, N, sec unit system.
 - The model has two systems: Body and Suspension.
 - The Body system contains the Vehicle body (Frame) and Engine fixed to each other.
 - The Suspension system has three trailing arms connected with a torsional spring damper.
 - There are two unresolved motions used to drive the vehicle, Motion Left and Motion Right.
Create Rolling Systems
                From the Vehicle Tools menu, under Track
                        Builder select Rolling systems.
Figure 3.The Create rolling system dialog is shown below:
Figure 4. - Under Parent System, select Suspension.
                Select the Symmetric pair check box to create both the
                    left and right rolling system together.
                Note: The symmetry needs to be about the x-z plane. The Symmetric pair does not create MotionView pair entities, instead it creates two entity copies positioned in the symmetry plane.
 - Click on Attach to single/left and select the Frame body.
 - Click on Attach to right and select the Frame body.
 - Specify sysr_sprocket and Sprocket as the Rolling system varname and Rolling system label.
 - Select the Rolling system type as Sprocket.
                Enter the following parameters:
Center X Center Y Center Z Radius Thickness Number of Teeth 0 -500 400 200 100 16  -
                Click Apply to create the sprocket systems and continue
                    in the Creating rolling system dialog.
                The complete dialog is displayed below:
Figure 5. -
                Repeat steps 2 to 9 using the following table to create three symmetric rolling
                    systems of type Wheel.
                Tip: Use the Apply button to keep the dialog open when creating multiple rolling systems.
Parent System Attach to Single/Left Attach to Right Rolling system varname Rolling system label Center Radius Thickness X Y Z Suspension Front Arm-Left Front Arm-Right sysr_frontwheel Front Wheel 300 -500 0 200 100 Suspension Mid Arm-Left Mid Arm-Right sysr_midwheel Middle Wheel 800 -500 0 200 100 Suspension Rear Arm-Left Rear Arm-Right sysr_rearwheel Rear Wheel 1300 -500 0 200 100 The model with the rolling systems is shown below:
Figure 6. -
                Update the joint of Motion Left to Sprocket
                        LH Joint Rev by selecting the revolute joint in the
                        Sprocket LH system.
Figure 7. - Update the joint of Motion Right to Sprocket RH Joint Rev by selecting the revolute joint in Sprocket RH system.
 - Save the model as Track_RollingSystems.
Create Track Systems
                        Builder select Create Tracks.
Figure 8.The Create track dialog is displayed:
Figure 9. - Select Suspension as the Parent System.
 - Set the Wrap varname as sysw_trackleft and the Wrap label as Track Left.
                Enter 4 in the Total number of
                        Entities field to wrap on the four rolling systems that were
                    created.
                This will update the entity selector table to enter four values.
                Select Systems to wrap in the order shown below. Keep
                        Wraptype as Inside for each
                    system.
- Sprocket LH
 - Rear Wheel LH
 - Middle Wheel LH
 - Front Wheel LH
 - Select Single Pin as Chain/Belt Properties.
 - Enter Link length as 85.0, Link thickness as 40.0, and Link width as 150.0.
 - Enter 50 for Number of links/segments as suggested in the Minimum number of links.
 - Select 1-Rotation and bending stiffness for Link DOF.
 - Under Soil Interaction, select Soft Soil.
 - Under Soil terrain file, select heavy_clay_25_custom_obs.rdf from Altair HyperWorks installation directory <install_dir>\hwdesktop\hw\mdl\autoentities\properties\Tires\ALTAIR_SOFTSOIL\SoilLibrary.
                Select the Road Reference Marker as Soil
                        Reference Marker.
Figure 10. -
                Click OK to create the left side track.
Figure 11. Left Side Track Created - Open the Create Tracks dialog to build the right side track. The previous selections are stored in the dialog.
 - Set the Wrap varname as sysw_trackright and the Wrap label as Track Right.
                    system.
- Sprocket RH
 - Rear Wheel RH
 - Middle Wheel RH
 - Front Wheel RH
 - All other fields are already populated with the parameters from the left side track. Click OK to create the track and close the window.
                The completed model is shown below.
Figure 12. -
                Click on Road Tools to invoke the dialog.
Figure 13. - Under File, load the heavy_clay_25_custom_obs.rdf file from the installation directory <install_dir>\hwdesktop\hw\mdl\autoentities\properties\Tires\ALTAIR_SOFTSOIL\SoilLibrary.
                Under MDL, select a location to save the
                        heavy_clay_25_custom_obs.mdl file in the
                        <working directory>.
Figure 14. - Click OK to create the road graphics.
                After road graphics creation, select the road graphics
                    in the Model Browser under the created Road Graphics systems
                    and define the Road Reference Marker in the Entity Editor.
Figure 15.
Figure 16. -
                The Track with Terrain Graphics is shown below.
Figure 17. - Save the model as Track_complete.
Simulation and Post-Processing
                Under the Vehicle Tools menu, go to Run and open the
                        Analysis settings dialog.
Figure 18. -
                Select the Run Offline check box and click the
                        Run button.
Figure 19. - After the simulation finishes, open a new HyperView window to visualize the results.
                Click on the Open Model button, load the
                        Track_complete.h3d file in the panel, and click
                        Apply.
Figure 20. -
                From the Animation toolbar, click the
 (Start/Pause Animation) button to animate the
                    model.
Figure 21. -
                Click on the Contour option in the Ribbon to visualize
                    the soil plastic sinkage.
Figure 22. -
                From the panel, select Plastic Sinkage as result type
                    and click Apply.
Figure 23.
Figure 24. - Add a new HyperWorks session.
                From the menu bar, select the HyperGraph
                        Line Chart application.
Figure 25. - Click on Open model and load the Track_complete.abf file from the MotionSolve run.
                Under Y type select REQSUB, a list of soft soil results
                    is displayed. Select Track LH Link 0 and
                        RESULTS(2) to plot the sinkage of the left track link
                    0.
Figure 26.
Figure 27.
