Standard Views
Captures images of the model in 4 standard views - Isometric, Left, Top and Front views.
From the Report Ribbon, Add Modules tool group, click
 and select Standard Views
                        module.Or
Right-click at the Report or Chapter level and select .- Below are the properties associated with the Standard Views module.
Figure 1.- Name
 - Provide the name for the Standard Views module.
 - Model
 - Provide the location of the model in the list of HyperMesh windows in the session.
 - View Type
- Standard
 - Creates the four standard views of the model- Isometric, Left, Top and Front.
 - Predefined
 - Executes a predefined script and attach the output as an
                                            image. Note: You must provide a script file path.
