Property Summary
The Property Summary module generates summary of entire model properties, by its name, type and ID.
- Property Info with Type and ID
 - Properties browser view
 - Shell Thickness Summary
From the Report Ribbon, Add Modules tool group, click
 and select Property Summary
                        module.Or
Right-click at the Report or Chapter level and select .- Below are the properties associated with the Property Summary module.
Figure 1.- Name
 - The name for the Property Summary.
 - Model
 - Provide the location of the model in the list of HyperMesh windows in the session.
 - Table of all properties by its Name, Type and ID.
 - Replicate Properties browser view
 - The currently displayed tabular data in the Properties browser in HM will be copied into a table.
 - This option generates the entire model Shell-based property summary based on Shell thickness. It creates a distribution summary as Thickness, Material ID and Property ID.
 - Once executed, a table output for Shell Thickness Summary is generated as
                        follows:Info Model- Text Note. This is created only in Document or HTML reports.
Figure 2.Model Thickness in mm- Image file.
Figure 3.Model Material and Property IDs and plies 0°, 45°, -45°, 90° - Table.
Figure 4. - Once executed, a table output for Property Summary is generated.
Figure 5. Property Info with Type and ID.
