Model Checker Summary
Model Checker Summary module generates three basic tables outputs along with failed checks tables.
- ERROR Table
 - WARNING Table
 - INFO Table
 - Failed Checks Table
From the Report Ribbon, Add Modules tool group, click
 and select
                    module.Or
Right-click at the Report or Chapter level and select .- Below are the properties associated with the Model Checker Summary module.
Figure 1.- Name
 - The name for the Model Checker Summary module.
 - Model
 - Provide the location of the model in the list of HyperMesh windows in the session.
 - Model Checker Checks
- ERROR Table
 - Summary table for entire error check folder
 - WARNING Table-
 - Summary table for entire warning check folder
 - INFO Table
 - Summary table for info entire check folder.
 - Failed Checks Tables
 - Detailed table summary for total failed checks in Model Checker.
 - Export Options
- Checks Export Type
 - Available export check options are Failed, Passed and All.
 - Advanced
- Page Break
 - Check to add Page Break at end of the item.
 - Once executed, a table output for Model Checker Summary is generated.
Figure 3.
Figure 4.
