Mesh Quality Statistics
Creates a table of mesh quality parameters defined in criteria settings file.
From the Report Ribbon, Add Modules tool group, click
 and select
                    module.Or
Right-click at the Report or Chapter level and select .- Below are the properties associated with the Mesh Quality Statistics module.
Figure 1.- Name
 - Provide the name for the Model Quality Statistics module.
 - Model
 - Provide the location of the model in the list of HyperMesh windows in the session.
 - Basic
 - Select 2D or 3D or both elements for Mesh quality checks.
 - 2D Quality Checks
 - Select the required quality check parameters.
 - 2D Mesh Categories
 - Select the required mesh categories such as ideal, good, warm,fail and worst.
 - 3D Quality Checks
 - 3D Mesh Categories
                                and worst.Note: User can edit in the mesh quality criteria also in Criteria File Settings in Preferences.
 - Advanced
- Numeric Precision
 - Select the number of decimal places.
- Numerical Format
 - Select the numerical formats- Fixed, Scientific and Engineering.
- Auto Split Table
 - Provides the function to split up tables automatically based on the space available in the slide or page.
 - Once executed, a table output for Mesh Quality Statistics is generated:
