Apply linear, exponential, or bellcurve biasing to individual edges of a surface, and
        edit the elements size distribution.
            Element biasing can be used to improve element quality when transitioning from
                smaller to larger element sizes, and enables you to moderate the changes in aspect
                ratio from the start to the end.
            After you have created an initial mesh, bias the placement of nodes so that their
                intervals are not uniform in size. For example, you can designate that the smaller
                intervals go near the start of the edge, near the end of the edge, near both ends
                with larger intervals in the middle, or near the middle of the edge.
                From the microdialog, click
 and select the desired
                    method.
                Left-click to select the edge(s) to modify.
                Edit magnitude in the following ways:
                    - Increase individual edge values by holding Ctrl while left-clicking on an edge;
                        decrease individual edge values by holding Ctrl while right-clicking on an
                        edge.
                    - Scroll edge values by holding Ctrl while scrolling the mouse wheel up and down. Hovering
                        directly over an edge will only modify that edge; hovering over empty space
                        will modify all selected edges.
                    - Specify an edge value in the microdialog and
                        press Enter. If multiple
                        edges are selected, a common value will be applied. If multiple edges with
                        different edge values are selected, use the arrows in the microdialog to modify individual edge values
                        simultaneously, without applying a common value.
                        Update.
                    Tip: Clear your selection by left-clicking in empty space.
