Define meshing preferences.
Each element has an associated element configuration. An element configuration tells HyperMesh how to draw, store, and work with the element.
Solver cards supported for elements.
Use the Element Quality view to review element quality while simultaneously editing your model.
Explore the different types of 1D mesh you can create in HyperMesh.
Create and edit beam sections of different configurations.
Parts are created from inputs. Solid parts are generated for each island of surfaces while Shell parts are created for line regions whenever the thickness changes as well as at t-junctions.
Models that require 0D and 1D elements can be created through controllers.
Explore the different types of 2D mesh you can create in HyperMesh.
Explore the different types of 3D mesh you can create in HyperMesh.
ON THIS PAGE
ON THIS PAGE
