Moldflow
Moldflow-specific checks used to calculate element quality for 2D and 3D elements.
Additional element checks not listed here are not part of the solver’s normal set of checks, and therefore use HyperMesh check methods.
2D and 3D Element Checks
- Aspect Ratio
 - Only applied to triangles, with quadrilaterals given a value
                                of:
3D Element Only Checks
- Vol. Aspect Ratio
 - Finds the perpendicular height h of each node, and then dividing the
                            longest edge length L by the shortest height h and multiplying by the
                            square root of 1.5:This results in an equilateral tetrahedron having a volume aspect ratio of 1.5. Non-tetrahedral elements are assigned a value of 1.0.
