Legend Preferences
The following legend options can be set in .
- Transparency
 - By default, the transparency option is turned on. Turning off transparency along with choosing the right background color helps to better visualize the legend if its overlapping the model.
 - Background Color
 - When the transparency option is turned off, select the legend's background color.
 - Divergent Color
 - By default, divergent color option is turned on. This can be turned off to get normal contour color.
 - No Result Color
 - The elements without contour results can be displayed in user-controlled color.
