| Displacement |
                NODE |
                VECTOR |
                | Velocity |
                NODE |
                VECTOR |
                | Acceleration |
                NODE |
                VECTOR |
                | Temperature |
                NODE |
                SCALAR |
                | Energy Results |
                NODE |
                SCALAR |
                Supported energy results include internal energy, hourglass energy. |
                | Time step related results |
                NODE |
                SCALAR |
                Supported results include time step size, mass scaling. |
                | CFD Data |
                NODE |
                SCALAR |
                Supported CFD types include pressure, vorticity (x, y, z, and resultant),
                  entropy, helicity, stream function, enthalpy, density, turbulent kinetic energy,
                  and dissipation. |
                | Particle Data |
                NODE/PARTICLE |
                VECTOR/SCALAR |
                Supported particle results include displacement, velocity, spin energy,
                  translational energy, radius, leakage, and gas ID. |
                | Residual Forces and Moments |
                NODE |
                VECTOR |
                | Normal resultant force |
                ELEMENT (1D, 2D) |
                VECTOR |
                | Shear resultant force |
                ELEMENT (1D, 2D) |
                VECTOR |
                | Bending Moment |
                ELEMENT (1D, 2D) |
                VECTOR |
                | Stress |
                ELEMENT (1D, 2D, 3D) |
                TENSOR3-D |
                Thick shell support is for the mid-surface only. |
                | Strain |
                TENSOR3-D |
                Thick shell support is for the inner surface only. |
                | Plastic Strain |
                TENSOR3-D |
                Thick shell not supported. |
                | Thermal Strain |
                TENSOR3-D |
                | Effective plastic strain |
                SCALAR |
                | Pressure |
                SCALAR |
                | Thickness |
                ELEMENT (2D) |
                SCALAR |
                | Percent thinning |
                ELEMENT (2D) |
                SCALAR |
                | Interface force in global direction |
                NODE |
                VECTOR |
                Supported from INTFORC file |
                | Interface force - Normal |
                NODE |
                SCALAR |
                | Interface force - Surface |
                NODE |
                SCALAR |
                | Contact Gap |
                NODE |
                SCALAR |
                | Interface shear stress |
                ELEMENT |
                SCALAR |
                Supported from INTFORC file, includes shear stress in r and s
                  direction |
                | Interface pressure - Normal |
                ELEMENT |
                SCALAR |
                | Interface force-segment |
                ELEMENT |
                VECTOR |
                Supported from INTFORC file (For Fluid structure interaction) |
                | Interface pressure-segment |
                ELEMENT |
                SCALAR |
                Supported from INTFORC file(For Fluid structure interaction) |
                | Peak Pressure |
                ELEMENT |
                SCALAR |
                | Time to peak |
                ELEMENT |
                SCALAR |
                | Surface energy density |
                ELEMENT |
                SCALAR |
