Interfacing with Animator DB
Overview of how the HyperView applications interface with Animator DB.
- Only the first Animation model is read from a multi-model a4db.
 - Adaptive models are not supported.Note: For XY plot data support refer to the HyperGraph Solver Interfacing section.
 - The following element types are supported: Quad, Quad8, Hexa, Hexa20, Bar, Beam, RBE, nel, Mass, Spring, Joint, Spotweld
 - Components are created based on the property information, if there is no property associated with an element, such elements are grouped under the component id = 9999.
 - Reading of following results is supported:
- Displacement
 - Failed elements (mapped to eroded elements in HyperView )
 - Functions (mapped to scalar datatypes in HyperView )
 - Function_node_element (mapped to scalar corner data in HyperView )
 - Vector4 (mapped to vector datatypes in HyperView )
 - Tensors (mapped to tensor datatypes in HyperView )
