HyperView Interfacing – UNV Files
When you select a model or results file, HyperView automatically detects the file type and selects the proper reader to import the data. If more than one reader claims to support the selected file format, a dialog listing those readers is displayed. From this dialog, you can select the preferred reader.
To extract only a selected set of results, use the external translator HvTrans to create an H3D file.
Solver Interface Support
- Block 15
 - Contains nodes
 - Block 82
 - Contains nodal connectivity
 - Block 55
 - Contains results
 - Block 151
 - Information related model title, created date, file type…etc
 - Block 164
 - Units information
 - Block 780
 - Element information
 - Block 781
 - 3 dimensional node coordinates
 - Block 2411
 - Nodal information
 - Block 2412
 - Element information (new format)
 - Block 2470
 - Property names
 - Block 2477
 - Node and element set information
 - Block 2420
 - System information
 - BLOCK55
 - Is updated to read complex first order Eigenvalues.
 - BLOCK2414
 - Contains results
 - BLOCK2412
 - Element information (new format). Membrane elements: 71 Membrane Linear Quadrilateral, 72 Membrane Parabolic Triangle, 74 Membrane Linear Triangle, 75 Membrane Parabolic Quadrilateral.
 - Block2470
 - Property label and component name
 - Block2477
 - Element and node group (sets)
These blocks may be created by applications outside of I-DEAS.
