CFD AcuSolve Reader Options
Control CFD AcuSolve Reader options by clicking Reader Options from the Load Model and Results panel.
- Extended nodal output
- No (default)
 - HyperView will only load the Nodal Output variable listed in the Supported Results.
 - Yes
 - HyperView will load all of the available result data in the AcuSolve result file.
 - Display mesh movement
- Yes (default)
 - HyperView will display mesh movement.
 - No
 - HyperView will not display mesh movement.
 - Load only the last step
- Yes (default)
 - HyperView will load only the last output result file. For a steady state analysis with intermediate result output files, HyperView will display the final steady state result.
 - No
 - HyperView will load all of the available result files. You can animate and display each result file individually.
 - Reset time
- No (default)
 - HyperView will not modify time.
 - Yes
 - HyperView will reset time to start from zero.
 - Read duplicate boundaries
- No (default)
 - HyperView will not read duplicate surfaces from mesh definition.
 - Yes
 - HyperView will read duplicated surfaces from mesh definition.
