Create Thermal Elements
Use the Thermals tool to create 0D/1D thermal elements.
A thermal element is an element created in a space between two nodes of a model where thermal properties are desired.
Update Thermal Elements
Use the Entity Editor to update thermal elements for the desired keyword.
This includes modifying the assigned nodes, property, and so on where applicable for the solver.
