Extract Midsurfaces
Use the Midsurfaces: Automatic tool to extract the midsurface of sheet metal stampings, molded plastic parts with ribs, and other parts that have thickness clearly smaller than width and length.
Midsurface Method Options
The following methods are available when extracting the midsurfaces of thin solids.
Access this option by clicking
 on
                the guide bar.
- Planes + Sweeps + Offsets
 - Identify the places where a piece of plane or a piece of a sweep surface
                            can be used as a middle surface. A middle surface is constructed at the
                            remaining places in the model, for example the places where planar or
                            sweep surface pieces cannot be used as a middle surface, by the same
                            algorithm as in offset via the offset of the model's sides.
Figure 2. - Planes + Offsets
 - Identify the places in the model where a piece of plane can be used as a
                            middle surface. At the remaining places in the model, for example the
                            places where planar pieces cannot be used as a middle surface, the same
                            algorithm as in Offsets is used to construct the middle surface via the
Figure 3. - Offsets
 - Create pieces of the middle surface by offsetting the model's side
                            surfaces towards the middle. This is the traditional approach for
                                midsurfacing.
Figure 4. - Skin Offset
 - Automatically detects the two largest faces on the model, detects the thickness, and then creates the middle surface by offseting one of the faces towards the other one by half of thickness. This is the quickest method for creating a midsurface. However, it is not applicable to many models.
                    to define midsurface options.
