Instantiate Entities
Use the Instantiate Entity tool to duplicate N time with a given prefix name (material, property, load collector).
From the menu bar, click .
You can create a template entity with all of the active data names and attributes and then modify using the Matrix Browser. The Matrix Browser cannot create new entities but it can modify existing ones.
- New material database sync with Excel
 - LOAD card (load combination cards) sync with Excel
 - Property generation and update
