Aircraft Transformation
Apply a full transformation (translation and rotation) to the element, node, component and system entities.
- From the menu bar, click .
                Select a method to input the transformation matrix.
- By config file: Import a CSV, structured like the
                        example shown below.
Figure 1.Note: Once the file has been loaded, you can set up reference and destination points. - By direct input: Directly input the transformation matrix in the fields.
 - By system: Select the reference and destination system from those available in the HyperMesh database. The transformation matrix that is found will be stored as a .csv file.
 - By three nodes: Three nodes as reference and
                        three nodes as destination are used for the transformation. You can also
                        save the transformation matrix as a .csv
                            file.Note: When the entity Component is selected you can transform the associated systems that were found.
 - Click Create.
