Project Vectors on a Cross Section Plane
                From the Plot tools, click the Vector tool.
                    Figure 1.  -
                From the Vector panel, click the Section tab (located in
                    the middle of the panel).
                Note: The Section options will only be enabled if all of the following conditions are met:
- A section cut has been applied to the model.
 - The Selection input collector is set to Sections.
 - The Resolved in system is set to Global.
 - Activate the Projected option to project the vectors to the cross section plane.
                Activate the Evenly distributed option to evenly
                    distribute the vectors on a cross section.
- Enter the desired number of rows that will be used to evenly distribute the vectors.
 - Enter the desired number of columns that will be used to evenly distribute the vectors.
Note: The Evenly distributed option must be activated in order to enable these options.Tip: You can also use the command layer to change the updating policy for the vector plot on the cross section.
