Align a Tracking System with Global Coordinate Systems
This can be useful for obtaining intrusion outputs in the global orientation while removing the rigid body motion. Displacement-based contour and vector plots, as well as all location based measures like position, relative displacement, and distance between are affected when the Use tracking option is selected.
- From the Create tools, select .
 - Select a tracking system from the Tracking Systems list.
 - Activate the Align with global (T=0) check box.
