Select a Projection Rule
                From the Plot tools, click the Tensor tool.
                    Figure 1.  -
                From the Tensor panel, click the Projection Rule
                    button.
                The Projection Rule dialog is displayed.
                Select the primary and secondary axes from either the global or user-defined
                    system (selected for Resolved in).
                When the primary axis is perpendicular to the shell plane, the secondary axis is used.See the Projection Rule topic for additional information.
