| Elemental |
                        Select to review the orientations of the following element systems:
                                    - 1D elements, shells, and solids
                                            - 1D Bars, Beams, Rods, etc. are supported for
                                                  OptiStruct and
                                                  Nastran solvers. See
                                                the HyperView Solver
                                                Interfacing topic for information regarding all of
                                                the supported element types.
                                        Known Limitations:
                                                - The location of the 1D systems on HyperMesh and
                                                  HyperView may be
                                                  different, depending on the end/offset conditions,
                                                  however the orientations should match. HyperView draws systems at the
                                                  centroid of the 1D element.
                                    - 2D and 3D
                                            - Penta6 in HyperView and
                                                  OptiStruct are
                                                different from Nastran.
                        | Material |
                        Select to review the orientations of various material systems.
                                    - Material
                                            - Plot composite stress/strain in Elemental, Material,
                                                Global, or User-defined systems.
                                            - Overlay tensor plots (composite stress/strain) with
                                                material direction plot.
                                            - Material systems are available as resolved in
                                                systems in Contour/Iso/Tensor panels for the data
                                                types supported.
Known Limitations:
                                    - For plotting data types that do not have relevance to the
                                        Material system (for example, Stress with Z1 and a Z2 data
                                        type), it is not advised that you apply the Resolved-in
                                        system of Material, because this can result in incorrect
                                        transformations.
                                    - Composite stress is required as a data type in order to view
                                        ply layers in the dialog.
                                    - See the HyperView Solver
                                        Interfacing topic for information regarding all of the
                                        supported solver and element types.
                        | Ply |
                        Select to review the orientations of various ply systems.
                                    - Ply
                                    - Ply systems are available as resolved in systems in
                                        Contour/Iso/Tensor panels for the data types supported.
Known Limitations:
                                        Ply system (for example, Stress with Z1 and a Z2 data type),
                                        it is not advised that you apply the Resolved-in system of
                                        Ply, because this can result in incorrect transformations.
                                    - See HyperView Solver Interfacing
                                        for information regarding all of the supported solver and
                                        element types.
