Use Scalable Fonts under Linux to Render Text
HyperView uses scalable fonts for Linux to render text in the 3D window.
Installing and Configuring Scalable Fonts
It is important that the correct fonts are installed for your operating system. Issue the
        command xlsfonts | grep 0-0 | grep iso8859-1 to list the fonts. By default,
          HyperView uses Helvetica and Times. Under RHEL7 and RHEL 7,
        the fonts list should include b&h luxi sans, b&h luxi serif as well as several other
        typeface families. On SLES 12, the font list should include b&h luxi sans, b&h luxi
        serif, bitstream vera sans, and bitstream vera serif.
Configure Missing Scalable Fonts on Linux for SLES12
                Verify that
XFree86-fonts-scalableandxfsare installed. -
                Use
chkconfigas the root user to ensurexfsis configured to run under run level 5. -
                You may have to add
FontPath "unix/:7100"under the Files section of/etc/X11/XF86Config.
Configure Missing Scalable Fonts on Linux for RHEL6 and RHEL7
Verify the X Window Server is Properly Configured for the Correct Display DPI Setting
xdpyinfo and examine the section starting with
                        "screen #0". It should look like this:
                screen #0:
  dimensions:    1280x1024 pixels (361x271 millimeters)
  resolution:    90x96 dots per inch
