Exporting and Saving a Query Table
                From the Query panel, click Export.
                The Output File dialog opens.
                Select the directory to which you want to save the text file.
                Note: The initial directory displayed is the present working directory.
                Enter a file name in the File name field, or accept the
                    default file name, "result".
                Tip: If you want to open the file in Excel, give the file a .csv extension.
 - Click Save.
