Manage a Path
- From the Path table/list, select a path.
                Edit the label for the path by clicking in the Label
                    field and entering in a new label.
                Note: The ID for the path is not editable.
                Specify the number of points dividing the path into equal segments by clicking
                    in the Num. Points field and entering in a value (the
                    maximum allowable value is 1000).
                Tip: You can also check the box in the Intersection column to have HyperView automatically generate the points at the intersection of the path with the element edge or face.
 - Activate the Review check box to highlight the currently selected path in the modeling window.
 - Select/change the review color of the path by clicking on the Color box and selecting a new color from the palette.
