Static Roll Analysis
A quasi-static simulation during which a rolling movement is applied to the suspension and various parameters are calculated.
Required input
- Tire static loaded radius (mm)
 - Tire vertical spring rate (N/mm)
 - Vehicle CG height (mm)
 - Wheel base (mm)
 - Front braking ratio
 - Front drive ratio
 - Axle ratio
 - Vehicle weight (N)
- Initial wheel position to begin rolling (mm)
 - Roll displacement magnitude (mm)
Task Description
The suspension is moved to the initial wheel position. This is followed by a left and right rolling movement during which displacements of equal magnitude in the opposite direction is applied.
Output
Reports containing some plots, tabular results, and graphical animation are automatically created.
- Wheel Center Displacement
 - mm
 - Ground Reaction Force
 - N
 - Toe-in
 - deg
 - Steer Angle
 - deg
 - Camber Angle
 - deg
 - Roll Angle
 - deg
 - Tread Width
 - mm
 - Tread Change
 - mm/m
 - Track Width
 - mm
 - Wheel Center X Stiffness
 - N/mm
 - Wheel Center Y Stiffness
 - N/mm
 - Wheel Center Z Stiffness
 - N/mm
 - Wheel Center XX Stiffness
 - N-m/deg
 - Wheel Center YY Stiffness
 - N-m/deg
 - Wheel Center ZZ Stiffness
 - N-m/deg
 - Parallel Lateral Force Deflection
 - mm/kN
 - Converging Lateral Force Deflection
 - mm/kN
 - Parallel Lateral Force Steer
 - deg/kN
 - Converging Lateral Force Steer
 - deg/kN
 - Parallel Lateral Force Camber
 - deg/kN
 - Converging Lateral Force Camber
 - deg/kN
 - Parallel Aligning Torque Steer
 - deg/100N-m
 - Converging Aligning Torque Steer
 - deg/100N-m
 - Longitudinal Force Deflection @ Wheel center
 - mm/kN
 - Longitudinal Force Deflection @ Tire patch
 - mm/kN
 - Longitudinal Compliance Steer @ Wheel center
 - deg/kN
 - Longitudinal Compliance Steer @ Tire patch
 - deg/kN
 - Longitudinal Caster Compliance @ Wheel center
 - deg/kN
 - Longitudinal Caster Compliance @ Tire patch
 - deg/kN
 - Side View Swing Arm Length
 - mm
 - Side View Swing Arm Angle
 - deg
 - Side View Swing Arm Fore/Aft Location
 - mm
 - Side View Swing Arm Vertical Location
 - mm
 - Front View Swing Arm Length
 - mm
 - Front View Swing Arm Angle
 - deg
 - Front View Swing Arm Lateral Location
 - mm
 - Front View Swing Arm Vertical Location
 - mm
 - Ride Steer
 - deg/m
 - Ride Camber
 - deg/m
 - Roll Steer
 - Roll Camber
 - Roll Inclination
 - Wheel Rate
 - N/mm
 - Ride Rate
 - N/mm
 - Hop Rate
 - N/mm
 - Suspension Roll Rate
 - N-m/deg
 - Total Roll Rate
 - N-m/deg
 - Tramp Rate
 - N-m/deg
 - Roll Center Height
 - mm
 - Roll Center Lateral
 - mm
 - Anti-lift
 - Acceleration Lift
 - mm/g
 - Anti-dive
 - Brake Dive
 - mm/g
 - Tractive Force Steer
 - deg/g
 - Tractive Force Windup
 - deg/g
 - Brake Steer
 - deg/g
