Predefined Paths
[FEEDFORWARD_STEERING]
TAG = 'FEEDFORWARD'
LOOK_AHEAD_TIME = 0.5
PATH = 'PREDEFINED'
BLOCK = ‘PATH'
INTEGRATION_STEP_SIZE = 0.01
[PATH]
TYPE = 'CONSTANT_RADIUS'
RADIUS = 40
INITIAL_STRAIGHT = 10
ENTRY_ANGLE = 0.39
| [CONSTANT RADIUS] | ||
| TYPE | Attr - string | REQUIRED <CONSTANT_RADIUS>  |
| RADIUS | Attr - real | REQUIRED Radius of the circle.  |
| INITIAL_STRAIGHT | Attr - real | REQUIRED Length of the initial straight before entering the turn.  |
| TURN | Attr - string | OPTIONAL
Similarly,
[PATH]
TYPE = 'SLALOM'
NUMBER_OF_CONES = 3
DESIRED_CG_LATERAL_DISP = 3
CONE_SPACING = 50
RECOVERY_LENGTH = 20
INITIAL_STRAIGHT = 20
| [SLALOM] | ||
| TYPE | Attr - String | REQUIRED <SLALOM>  |
| NUMBER_OF_CONES | Attr - int | REQUIRED Number of cones.  |
| DESIRED_CG_LATERAL_DISP | Attr - real | REQUIRED Desired CG lateral displacement.  |
| CONE_SPACING | Attr - real | REQUIRED Distance between adjacent cones.  |
| INITIAL_STRAIGHT | Attr - real | REQUIRED Straight section before entering slalom.  |
| RECOVERY_LENGTH | Attr - real | REQUIRED Straight section after completing slalom.  |
| ATTACK_DIRECTION | Attr - String | OPTIONAL
Path as sequence of straights and arcs:
[FF_STEER_CONTROLLER]
TAG                     = 'FEEDFORWARD'
PATH                    = 'SEQUENCE_OF_ST_CRV'
BLOCK                   = 'PATH'
INTEGRATION_STEP_SIZE   = 0.010000
AGGRESSIVE              = 'TRUE'
[PATH]
{KEY        PAR0              PAR1}
'ST'        20.000000         0.000000
'ARC'       40.000000        -6.283184
Figure 3.
[PATH]
{KEY        PAR0              PAR1}
'ST'        17.033191         0.000000
'ARC'       20.000000         -0.148890
'ST'        17.240436         0.000000
'ARC'       20.000000         0.148890
Figure 4.
