Remove Objectives and Constraints
- If a Response Variable is deleted, the corresponding objective and constraint (which uses the RV) will automatically be deleted.
 - If a Response Variable is suppressed, the corresponding objective and constraint (which uses the RV) will automatically be greyed out and it will not be used for the study (see below).
