Add Objectives and Constraints
                From the Optimization Setup section of the Optimization Wizard, click the
                        Add button in its respective section.
Figure 1. -
                Choose the response from the list of available responses.
                Restriction: Only one objective and/or constraint can be added per response. Thus, the maximum number of total objectives or constraints cannot exceed the total number of active responses in the study.
