MF-Tyre/MF-SWIFT Modeling
MotionView integrates MF-Tyre and MF-SWIFT tire models from Siemens (branded by Siemens as Simcenter Tire).
- Turnslip
 - MF-Swift tire model with Rigid Ring
 - Enveloping Tire/Road Contact
 - Temperature and Velocity (MFSwiftTV)
To use MF-Tyre/MF-SWIFT with your MotionView model, add an AutoTire entity from the MBD-Vehicle Dynamics Tools to your model. See Accessing Auto Entities in MotionView and AutoTire - Auto Entity for more information. Once you have added an AutoTire, select an MF-Tyre/MF-SWIFT property file. You can find example property files in the installation here:
…\hwdesktop\hw\mdl\autoentities\properties\Tires\MF_SWIFT
To learn what MotionSolve statements are used to interface MF-Tyre/MF-SWIFT with MotionSolve, see the MF-SWIFT/MF-Tyre Integration with MotionSolve topic.
