Clip Details
In the Clip details component, you can enter the required number of clips that have to be included in the Total number of Clips text field.
- Direction
 - Defines the direction of the clip from center bolt either Front or Rear.
 - Distance
 - Defines the distance of the clip from center bolt in the ‘direction’ specified.
 - Clip
 - Depending upon the requirements, you can choose any clip label from the drop-down menu.
Figure 1. Clip Details
Rebound Clip Block for Leaf Property File (*lpf)
- Clip Table Sub-block
 - In the Clip Table sub-block of the Leaf Property file, the attribute, type,
                        and valid value to be entered in TiemOrbit file format are detailed in the
                        following table. This table also provides information about the mandatory
                        requirements for attributes.An example of how a Clip Table block is represented in a TiemOrbit file format is shown below:
$-------------------------------------------------REBOUND_CLIP_LIST [REBOUND_CLIP] (CLIP_TABLE) {CLIPNO CLIPLABEL DIRECTION DISTANCE} 1 CLIP_1 FRONT 596.5 2 CLIP_2 REAR 596.5- Block Name = ‘Rebound_Clip_List’ (Required)
 - Sub-block name = ‘CLIP_TABLE’ (Required)
Attributes Type Valid Value Required clipNo Integer 1, 2 ... Yes clipLabel String String Yes direction String FRONT REAR
Yes distance Real Value should be in the range of leaf lengths. Yes
