Produce S. Dietz's "frequency response mode" for Multibody Analysis
                Perform a normal analysis without constraint
                    (free-free).
                Read results.
- m
 - System mass matrix (Lumped mass).
 - Xn
 - Free-Free normal modes including the rigid body modes
(Xn=[Xr,X1,X2,....,Xk]). - Dn
 - Diagonals are the eigenvalues associated with Xn.
                Perform a "special" static analysis without
                    constraint in FE:
( k - l * m ) * Xf = Fawhere,- k
 - System stiffness matrix.
 - l
 - A scalar, usually half of the first nonzero frequency of the free-free normal analysis in step 1.
 - m
 - Fa
 - Attachment forces at junction nodes, not necessarily unit loads.
Read results.- Xf
 - The "frequency respond mode" associated with l and Fa (the displacement from the "special" static analysis).
                Form modal stiffness matrix KHAT as:
KHAT= | Dn Xn'*Fb | | Fb'*Xn Xf'*Fb |where Fb is the balancing force and is defined as:Fb = Fa + l*m*XfForm modal mass matrix MHAT as:MHAT=X'*m*Xwhere X is the combined mode:X=[Xn Xf] -
                Orthogonalize X by solving the following eigen problem:
KHAT*N=MHAT*N*DIf X is not independent, then one of the following occurs:- The eigenvalues/vectors are complex
 - Some highest eigenvalues are infinite
 - Extra zero eigenvalue rigid body modes
In either case, the corresponding modes can be filtered out so this step removes dependent modes as well.
                Transform X to orthoginalized modes Y:
Y=X*NThis is the mode set of rigid body modes, free-free normal modes, and S.Dietz's "frequency response mode" modes.
The generalized mass and stiffness matrix are:M=N'*MHAT*N=I K=N'*KHAT*N=DY, D, and m are used to calculate the flexible MB input file.
