Produce Craig-Chang Modes for MB Analysis
                Perform a normal analysis without constraint
                    (free-free).
                Read results.
- m
 - System mass matrix (Lumped mass).
 - Xr
 - Rigid body modes (mass orthonormalized
(Xr'*m*Xr=I)) - Xn
 - Free-Free normal modes including the rigid body modes.
 (Xn=[Xr,X1,X2,....,Xk]).- Dn
 - Diagonals are the eigenvalues associated with Xn.
                Form the equilibrated load matrix Fe:
Fe = P*FaWhere,P=I-m*Xr*Xr'and Fa has unit force along each DOF of the interface nodes.
                Perform a static analysis without constraint and
                    with (1) restraint to remove the rigid DOF. Allow all elastic deformation
                    subcases (2) where columns of Fe are applied at each subcase (i.e.
k*Xa=Fe).Read results.- Xa
 - Inertial relieve attachment modes, or displacement of static analysis.
                Form modal stiffness matrix KHAT as:
KHAT | Dn Xn'*Fe | | Fe'*Xn Xa'*Fe |and modal mass matrix MHAT as:MHAT=X'*m*Xwhere X is the combined mode:X=[Xn Xa]Orthogonalize X by solving the eigen problem:KHAT*N=MHAT*N*DIf X is not independent, then one of the following occurs:- The eigenvalues/vectors are complex
 - Some highest eigenvalues are infinite
 - Extra zero eigenvalue rigid body modes
In either case the corresponding modes can be filtered out so this step removes dependent modes as well.
                Transform X to orthoginalized modes Y:
Y=X*NThis is the mode set of rigid body modes, free-free normal modes, and the residual inertial relieve attachment modes. The generalized mass and stiffness matrix are:M=N'*MHAT*N=I K=N'*KHAT*N=DY, D, and m are used to calculate the flexible MB input file.
