MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multibody dynamics models.
MotionView works with a neutral file called H3D to represent the flexible body. This compact file format stores the necessary information for visualizing the flexbody in the pre-processing window and the modes and interface nodes in the post-processing window. It also stores the modal and nodal information.
Once an H3D file is created, it can be visualized in HyperView.
MotionView models solved in MotionSolve or Adams can be animated in HyperView. In addition, the plots for these models can also be viewed in HyperGraph.
HyperView supports post-processing of transient analyses and modal (ADAMS Linear) analyses of ADAMS simulations that contain flexbodies.
Add an FMU to the model or export a model as an FMU.
Reference material for the scripting interface which is a set of Tcl/Tk commands.
                    Figure 1. © 2023 Altair Engineering, Inc. All Rights Reserved.
