Animate Flexible Body Results and View Contours in HyperView
                Click the Open Model button
 on the Standard toolbar, or from the File menu select Open > Model.
                See Opening Files in HWD for additional information. -
                From the Load Model panel, verify that the Load model and Load results check
                    boxes are activated.
                    Figure 1.  -
                Click the Load model file browser
                The Load Model File dialog is displayed. -
                Open the ALTAIR.flx file.
                The same file is automatically loaded into the Load results field.
 - Click Apply.
                Click the Start/Pause button
 on the Animation toolbar to animate the results.
                Click the Contour panel button
 located on the Results toolbar.
                The Contour panel is displayed. - Use the Contour panel to view displacement or stress contours on the model.
