Connections define the two connecting bodies, the point where the forces act, and the
        marker that defines the bushing orientation. Bodies, markers, and points can be selected
        either graphically or through the Project Browser.
                From the Connectivity tab, select the first body to
                    connect.
The I marker of the Force_field statement in the solver
                    deck lies on Body 1, is located at Point 1, and has the orientation of Marker.
                    - Click Body 1 and select a
                        body from the modeling window.
                    - Double click Body 1 and
                        select the required body from the dialog.
                Similarly, select the second body to connect by
                    clicking the Body 2 input
                    collector.
The J marker of the Force_field statement in the solver
                    deck lies on Body, is located at Point 1, and has the orientation of
                    Marker.
                Select a marker to orient the bushing in space.
                    - Click Marker and select a
                        marker from the modeling window.
                    - Double click Marker and
                        select the required marker from the dialog.
                All three axes of the bushing are along the axes of the respective axes of the
                    Marker (X-X,Y-Y,Z-Z).
                Select a point to locate the bushing. The point defines the location where the
                    bushing forces act. The I marker and the J (floating) marker of the
                        Force_field statement are at Point 1.
                    - Click Point 1 and select a
                        point from the modeling window.
                    - Double click Point 1 and select the required
                        point from the dialog.
                Check the Output box to write
                    requests into the solver deck that request the force in the bushing, the
                    displacement across the bushing, and the relative velocity across the
                    bushing.
