In a multibody system, a rigid body is an ideal representation of solid body/part of
        fixed size and shape in which deformation is insignificant or neglected, or in other words,
        the distance between any two points of a rigid body remains unchanged (irrespective of the
        external forces acting on it). A rigid body will have six degrees of freedom (DOF) and
        therefore every additional rigid body in a multibody system adds an additional six DOF to
        the system.
                If the Bodies panel is not currently displayed, select the desired body by
                    clicking on it in the Project Browser or in the modeling window.
The Bodies panel is automatically displayed.
                Select the Properties tab and specify the mass and
                    inertia properties of the body by entering in the values in the appropriate
                    fields.
                    Note: If the selected body is a pair entity, first distinguish between the
                            Left and Right tabs in the
                        panel, and then edit the properties.
                    Tip:
                            - Check Flex Body (CMS) to convert a rigid body
                                definition to a flexible/deformable body.
                            - Check Symmetric properties to make the body
                                properties symmetric. Once this option is activated, MotionView will ask you which side of the
                                values of the pair entity (Left or Right) is to be used. Selecting
                                any one side will make values of that side as “leader” and the
                                values of the other side will gray out and follow the values on the
                                leader side.
                            - Check Get Properties from associated Graphics
                                to get the mass and inertia properties from the graphic associated
                                with the body. Activating this option will deactivate the Mass and
                                Inertia properties fields, and the CM Coordinates and Inertia
                                Coordsys tabs.
                Click the CM Coordinates tab.
                Click the Use center of mass coordinate system check box
                    to select a point as the origin of center of mass for the body.
                    Note: If a center of mass coordinate system is not specified, MotionView assumes that it coincides with the global
                        frame of the model.
                Click the Point collector and select the appropriate
                    center of mass point from the modeling window, or
                    double-click Point to display the Model Tree (from which the desired point can be
                    selected).
                Use the orientation options to orient the
                    coordinate system.
                Following the same steps as the center of mass, specify
                    the inertia coordinate system and the body coordinate system by using the
                        Inertia Coordsys and Body
                        Coordsys tabs respectively.
                    Note: The inertia coordinate system is the reference frame with respect to which
                        the inertia properties of the body are specified. If a unique inertia
                        coordinate system is not specified, then the specified moment of inertia
                        values are assumed to be defined about the center of mass marker. If a
                        unique body coordinate system is not specified, then it is assumed to be at
                        the global reference frame. This is valid for both single and pair body
                        types.
                Define initial conditions.
                        Click the Initial Conditions tab on the
                            panel.
                        Select the desired check boxes and enter values for translational and
                            rotational velocity.
                        Select a marker for VM and WM.
The translational initial conditions for a body are assumed to be with
                            respect to the global reference frame in absence of a unique VM (linear
                            velocity reference marker), and the rotational initial conditionals are
                            applied about the center of mass marker in absence of a unique WM
                            (angular velocity reference marker).
            Note:
                    - The inertia values are specified with regard to the inertia coordinate
                        system.
                    - MotionView does not check for the physical
                        correctness of the properties entered in the field (for example: I1 +I2 >=
                        I3 where I1, I2, and I3 are the principal moment of inertia of the
                        body).
                    - Specifying symmetric properties makes both pairs have the same values.
                        Verify the correctness of data by considering the orientation of the Inertia
                        coordinate system.
                    - When the Get Properties from associated Graphic(s) option is activated:
                            - The property values (mass, inertia, and CM origin) are obtained from
                                the following type of graphics: cylinder (both ends capped), box,
                                sphere and CADGraphic. File Graphics (H3D) is currently not
                                supported.
                            - The CM marker orientation is aligned with Global Frame. The Inertia
                                coordinate system is deactivated, which means that the inertia
                                properties displayed are with respect to the CM marker.
