Assembly Wizard Dialog
In MotionView, models are assembled from libraries of pre-defined systems using the Assembly Wizard, located on the Assembly ribbon. The Assembly Wizard dialog guides you through the assembly process, ensuring that your selections are compatible.
- Next
 - Moves to the next panel.
 - Back
 - Returns to the previous panel for review or edit.
 - Cancel
 - Closes the Assembly Wizard.
 - Reset Selection
 - Resets the assembly wizard.
 - Message Log...
 - Displays the message log at the bottom of the dialog.
 - Clear
 - Clears the message log.Note: This button is only activate if the message log is displayed.
Model Type
Driveline Configuration
Primary Systems
Figure 3.
Steering Subsystems
Figure 4.
Springs, Dampers, and Stabars
Figure 5.
Jounce/Rebound Bumpers
Figure 6.
Label and Varname Specifications
Figure 7.
Once you have made your selections, the Assembly Wizard retrieves the systems from the libraries and connects them in a hierarchical structure.
The attachments specified during the assembly process can be modified using the Attachment Wizard dialog.
