The user interface provides you with a consistent look and feel when you are working in any application.
Trace key points and objects in your video and set up a tracking system on an object in the video.
Apply annotations, headers, and footers to your video.
Compare video frames or overlay frames with other videos or images to watch them in flips.
Use the Overlay panel to alternate the display of overlaid images or movie files.
ON THIS PAGE
The duration of each flip and the number of flips match the values set in the panel.
ON THIS PAGE
