Filmstrip
Creates a 4x4 horizontal or vertical page layout that displays a series of frames for up to four media files at specified time offsets.
- Filmstrip layout
 - Select Horizontal or Vertical for the filmstrip layout.
 - Files
 - Use the file browser button to select up to four media files to be displayed.
 - Offset between frames
 - Each successive window is offset by the amount entered. Negative offset values are not allowed. MediaView voids any invalid entries and resets the value to the default.
 - Fit image to window
 - Scales the video image to fit the image in the area of the window in which it is contained.
 - Time Scales...
 - Displays the Synchronize Animation dialog. Use this dialog to synchronize windows that contain animation results in different units and/or begin at different time steps.
