Create a New Filmstrip Page
- From the Filmstrip panel, under Filmstrip layout, select Horizontal or Vertical.
 - Enter a value in the Offset between frames field.
 - Under Files, click the file browser button and select a file.
 - If you are using multiple movie files, repeat step 3 to select up to three additional movie files.
                Click Apply.
                Each successive window is offset by the amount entered.A new page is created with a 4x4 layout of the video images. The selected data file(s) is loaded into each window of either the first row or first column, depending upon the orientation.Note: Negative offset values are not allowed. MediaView voids any invalid entries and resets the value to the default.Tip: Select Fit image to window to scale the video image to fit in the window in which it is contained.
