File Reference - AMF Header
- Light Green
 - Number of frames stored least significant byte (LSB) first.
 - Royal Blue
 - Width of the image in pixels stored LSB first.
 - Dark Pink
 - Height of the image in pixels stored LSB first.
 - Cyan
 - Byte offset stored as a long integer (4 bytes) and stored LSB first.
 - Red
 - Four Character Code (4CC), which identifies compression type.
 - Yellow
 - Denotes the end of the AMF header section.
