Create a Frequency vs. Time Plot
                From the HyperGraph 3D toolbar, click the Waterfall
                    icon,
             - Under Plot type:, select Frequency from the first drop-down menu and Time from the second drop-down menu.
 - Under Data curves:, manually enter a p#w#c#.vector curve reference for Response=, or press Shift and left-click an RPM curve in HyperGraph.
Or
                Use the curve selector.
                         Click the curve selection button,
, in the Response text box to display the Response dialog.
                     - Choose a curve from the tree and click Select.
 - You can also click Preview to view the curve before selecting it.
 - Click Close to close the Curve dialog.
 - Under Waterfall slices:, select Number: and enter the number of slices for the waterfall plot.
Or
- Select Step size: and enter a step size based on the time vector of the response curve.
 - Click Apply.
