Create a New Plot Macro
                From the Math panel,
                    click Add.
                The Edit Plot Macro dialog is displayed.
 - Click the Parameters tab.
 - Click Add.
 - Enter a parameter name in the Parameter text box.
 - Enter a variable name for the parameter in the Varname text box.
 - For Type, select Curve or Scalar.
 - Click the Curve tab.
                Double-click on a parameter in the Parameters list.
                The variable name for the parameter is displayed in the Label text box.
 - For complex macros, activate the format for the data returned from the Y math expression by clicking the Real/Imaginary or Phase/Magnitude radio buttons.
 - Enter math expressions for the X and Y coordinates.
 - For parameters of type "curve", curve vectors can be referenced in the math expression. When referencing vectors from linear curves, use parameter_name.x and parameter_name.y for x and y vectors, respectively.
                When referencing vectors from complex curves, use the following naming
                    conventions:
- Vector Type
 - Naming Convention
 - X
 - parameter_name.x
 - Y
 - parameter_name.y
 - Y phase
 - parameter_name.yp
 - Y magnitude
 - parameter_name.ym
 - Y real
 - parameter_name.yr
 - Y imaginary
 - parameter_name.yi
 - Click Close.
 - Enter the macro name in the Macro text box.
 - If desired, rename the macro by highlighting the name from the list, entering a new name in the Macro field, and pressing Enter.
