Apply an Existing Plot Macro
- From the Math panel, select a macro from the list.
 - Type in scalar parameter values or select curves using the collectors.
 - Select a curve by pressing Shift and picking a curve from the screen or select a curve from the tree.
 - Select a method for placing the new curves from the Layout section.
 - Click Apply.
 - Click Undo to remove the macro.
