View Waterfall Plots from a Top View
- From the HyperGraph 3D Curve Attributes panel, click Top on the view controls, located in the lower right corner of the application.
 - Select the Surface tab.
 - Activate the Contour check box.
 - Under Expression:, set the contour expression to Z to see the Z values represented as the contour.
